DIMTXT system variable
Text height
Controls the default dimension text height, if the text style set in the DIMTXSTY system variable has no fixed height.
| Type: | Real |
| Saved in: | Drawing |
| Default value: |
0.18 Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 2.5.
