DIMTZIN system variable
Tolerance suppress zeros
Specifies the suppression of zeros in tolerance values. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 15 |
| Default value: | 0 |
| Possible options: |
0: Suppress zero feet and precisely zero inches 1: Include zero feet and precisely zero inches 2: Include zero feet and suppress zero inches 3: Suppress zero feet and include zero inches 4: Suppress leading zeros in decimal dimensions 8: Suppress trailing zeros in decimal dimensions |
