DIMZIN system variable
Suppress dim zeros
Suppresses leading and/or trailing zeros for primary units.
| Type: |
Short |
| Saved in: |
Drawing |
| Range: |
0 to 15 |
| Default value: |
0 |
| Possible options: |
0: Suppress zero feet and precisely zero inches 1: Include zero feet and precisely zero inches 2: Include zero feet and suppress zero inches 3: Suppress zero feet and include zero inches 4: Suppress leading zeros in decimal dimensions (for example: 0.1000 becomes .1000) 8: Suppress trailing zeros in decimal dimensions (for example: 11.1000 becomes 11.1) |
Note:
- Options 0, 1, 2, and 3 affect feet and inch dimensions.
- Select bit flags 4 and 8 to suppress both leading and trailing zeros in decimal dimensions (for example: 0.1000 becomes .1).
