DISPLAYTRUEDIMENSION system variable
Default dimension type
Sets the default dimension type placed on an isometric view.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: Projected - not aligned with geometry. 1: True - aligned with geometry |
