DMAUDITLEVEL system variable
DMAUDIT command, level of details
Specifies whether certain types of errors are reported by the DMAUDIT command. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
| Type: | Short |
| Saved in: | Workspace |
| Range: | 0 to 3 |
| Default value: | 1 |
| Possible options: |
1: Ignore dynamic range errors 2: Ignore sliver faces |
