DMAUTOUPDATE system variable
3D constraints recalculation mode
Updates the model automatically, when constraints are applied or modified.
If off, use the DMUPDATE command to update the model.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Don’t update 3D constraints automatically On (1): Update 3D constraints automatically |
