DMAUTOUPDATE system variable
3D constraints recalculation mode
Specifies if a model automatically updates when 3D constraints are added or edited. If this setting is switched off, command DMUPDATE must be used to update the model.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: | Off (0): Don’t update 3D constraints automatically On (1): Update 3D constraints automatically |
