DRAGMODECONSTRAINTS system variable
Solve 3D constraints dynamically
Solves 3D constraints live when entities are moved.
Turn off to optimize performance.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Disable dynamic solution of 3D constraints On (1): Enable dynamic solution of 3D constraints |
