DRAGOPEN system variable
Drag open
Specifies if a drawing file that is dragged onto the application inserts into the current drawing or opens as a separate drawing.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 1 |
| Default value: | 1 |
| Possible values: | 0: Insert file 1: Open file |
