DRAGSNAP system variable
Snap dragged entities
Enables rubber band dynamics during modify commands: COPY, PASTECLIP, PASTEBLOCK, MOVE, ROTATE, MIRROR, SCALE, STRETCH and more.
The DRAGSNAP system variable controls the snap behavior while dragging. DRAGSNAP controls whether rubberband dynamics are displayed at the current cursor location or at the current entity snap location.
Note: Rubber band dynamics means that the cursor and the entity being modified will jump to the active snap point, this will make to target location more obvious.
  • If on, the cursor and any selected entities will jump to the active snap point, this will make the target location more obvious.
  • If off, snap is only in effect during drawing and editing commands.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t snap dragged entities
On (1): Snap dragged entities
