DRAWINGVIEWASM system variable
Assemblies optimization
Enables the use of assembly data structures, optimizes the generation of views created with the VIEWBASE command.
Toggles between normal analytical hidden line removal (HLR) and ASM_HLR procedure.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Disable assemblies optimization On (1): Enable assemblies optimization |
