DRAWINGVIEWFLAGS system variable
Drawing View Flags
Enables the settings for drawing view related commands (for example, VIEWBASE, VIEWUPDATE).
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 3 |
| Default value: |
0 |
| Possible options: |
0: Disable the settings for the drawing views 1: Enable parallel generation and update of views 2: Enable background generation of views |
