DROPGEOMMODE system variable
Drop geometry mode
Enables or disables the internal DROPGEOM command. If enabled, geometry can be dragged by clicking and holding the primary mouse button.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
Off |
| Possible values: |
Off (0): Disable DROPGEOM. On (1): Enable DROPGEOM. |
