DXFTEXTADJUSTALIGNMENT system variable
DXF text adjust alignment
Controls if alignment is adjusted when text is loaded from a DXF.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t adjust alignment On (1): Adjust alignment |
