DYNDIMAPERTURE system variable
Dynamic dimension aperture
Controls the radius around the cursor, used to detect the nearest entity during a command, in pixels. Applies only when the DYNMODE system variable is set to Nearest entity dynamic dimensions.
Values between 1 and 500 are accepted.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 500 |
| Default value: |
20 |
| Unit |
pixels |
