DYNDIVIS system variable
Dynamic dimension visibility
Controls which dynamic dimensions are displayed when grips are moved.
| Type: | Short  |
| Saved in: | Registry  |
| Range: | 0 to 2  |
| Default value: | 1  |
| Possible values: |
                            0: Only the first dynamic dimension 1: Only the first two dynamic dimensions 2: All dynamic dimensions, as specified by DYNDIGRIP  |
