DYNMODE system variable
Dynamic input mode
Turns dynamic input features on and off. The value is stored as a bitcode using the sum of the values of all selected options.
| Type: | Short |
| Saved in: | Registry |
| Range: |
-31 to 31 |
| Default value: | 3 |
| Possible options: |
Negative: Switch all off temporarily 0: No dynamic input 1: Dynamic input at pointer (not supported) 2: Editable dynamic dimensions 4: Tracking dynamic dimensions 8: Nearest entity by UCS X/Y axes dynamic dimensions 16: Nearest entity dynamic dimensions |
