DYNPROMPT system variable
Dynamic input command prompts
Display command prompts in dynamic input tooltips.
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t display command prompts
On (1): Display command prompts
Note: The On value of the DYNPROMPT system variable is ignored if bitcode 1 (not yet supported) or 2 of the DYNMODE system variable are not selected.
