DYNPROMPT system variable
Dynamic input command prompts
Display command prompts in dynamic input tooltips.
| Type: |
Boolean |
| Saved in: |
Registry |
| Default value: |
On |
| Possible values: |
Off (0): Don’t display command prompts On (1): Display command prompts |
Note: The On value of the DYNPROMPT system variable is ignored if bitcode 1 (not yet supported) or 2 of the DYNMODE system variable are not selected.
