ENABLEHYPERLINKTOOLTIP system variable
Hyperlink tooltip
Toggles the display of the hyperlink tooltip on/off.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
Off |
| Possible values: |
Off (0): Disable hyperlink tooltip On (1): Enable hyperlink tooltip |
