EXPINSANGLE system variable
Explorer Insert Angle
The rotation angle used for blocks inserted from the Drawing Explorer.
Applies if the EXPINSFIXANGLE system variable is switched on.
BricsCAD only
| Type: |
Real |
| Saved in: |
Preference |
| Default value: |
0.0 |
| Unit |
degrees |
