EXPINSANGLE system variable
Explorer Insert Angle
The rotation angle used for blocks inserted from the Drawing Explorer.
Applies if the EXPINSFIXANGLE system variable is switched on.
BricsCAD only
Type:
Real
Saved in:
Preference
Default value:
0.0
Unit
degrees
Related variables
  • EXPINSFIXANGLE system variable
Related information
  • Drawing Explorer dialog box
