EXPINSFIXANGLE system variable
Explorer Insert Fix Angle
Uses a rotation angle for blocks inserted from the Drawing Explorer. See also the EXPINSANGLE system variable.
BricsCAD only
| Type: | Boolean |
| Saved in: | Preference |
| Default value: | On |
| Possible values: |
Off (0): Don’t insert blocks at fixed angle On (1): Insert blocks at fixed angle |
