EXPINSFIXSCALE system variable
Explorer Insert Fix Scale
Inserts blocks from Drawing Explorer at a fixed scale.
See the EXPINSSCALE system variable.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Preference |
| Default value: |
On |
| Possible values: |
Off (0): Don’t insert blocks at fixed scale On (1): Insert blocks at fixed scale |
