EXPINSSCALE system variable
Explorer Insert Scale
The scale multiplier used for blocks inserted from the Drawing Explorer.
Applies if the EXPINSFIXSCALE system variable is switched on (1).
BricsCAD only
Type:
Real
Saved in:
Preference
Default value:
1.0
Related variables
  • EXPINSFIXSCALE system variable
Related information
  • Drawing Explorer dialog box
