account
translation
Bricsys Help Center
EXPLMODE system variable
Explode mode
Enables the EXPLODE command on nonuniformly scaled (NUS) blocks.
Type:
Boolean
Saved in:
Registry
Range:
On
Possible values:
Off (0): Don’t explode nonuniformly scaled blocks
On (1): Explode nonuniformly scaled blocks
Related commands
  • EXPBLOCKS command
  • EXPIMAGES command
  • EXPLODE command
© 2025 Bricsys NV. All rights reserved.Privacy statement -Terms of use -Cookie statement
