EXPORT3DPDFWRITER system variable
3D PDF writer
Controls the writer used to save 3D PDF files.
BricsCAD only
Type:
Short
Saved in:
Registry
Default value:
2
Possible options:
0: Always use Communicator 3D PDF writer
1: Always use Mechanical 3D PDF writer
2: Prefer Communicator writer when available
Related commands
  • EXPORT command
Related information
  • Communicator for BricsCAD settings
  • Communicator for BricsCAD - Supported export file formats
  • Managing PDF files
Octave
