EXPORTHIDDENPARTS system variable
Hidden parts
Controls how hidden parts are exported.
Entities can be invisible because of:
Type: |
Short |
Saved in: |
Registry |
Range: |
0 to 1 |
Default value: |
0 |
Possible values: |
0: Export and hide if possible: Exports hidden entities. If the target format supports hidden entities, hidden entities in the source document will be hidden also in target document. 1: Do not export: Invisible entities are skipped. |
EXPORTHIDDENPARTS system variable - BricsCAD Lite & Pro | Bricsys Help Center
