EXPORTPAGESETUP system variable
Export page setup
Toggles the page setup for DWF, DWFx or PDF export.
Type:
Short
Saved in:
Drawing
Range:
0 to 1
Default value:
0
Possible options:
0: Default
1: Override
Note: The EXPORTMODELSPACE, EXPORTPAPERSPACE and EXPORTPAGESETUP system variables currently are dummies for DWF exports.
Related commands
  • EXPORT command
Related variables
  • EXPORTMODELSPACE system variable
  • EXPORTPAPERSPACE system variable
