EXPORTPARASOLIDFORMATVERSION system variable
Parasolid export format version
Controls the Parasolid file version to export to.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 27 |
| Default value: |
0 |
| Possible values: |
0: Latest available 1: Parasolid 12 2: Parasolid 13 3: Parasolid 14 4: Parasolid 15 5: Parasolid 16 6: Parasolid 17 7: Parasolid 18 8: Parasolid 19 9: Parasolid 20 10: Parasolid 21 11: Parasolid 22 12: Parasolid 23 13: Parasolid 24 14: Parasolid 25 15: Parasolid 26 16: Parasolid 27 17: Parasolid 28 18: Parasolid 29 19: Parasolid 30 20: Parasolid 31 21: Parasolid 32 22: Parasolid 33 23: Parasolid 34 24: Parasolid 35 25: Parasolid 36 26: Parasolid 37 27: Parasolid 38 |
