EXPORTPRODUCTSTRUCTURE system variable
Product structure
Defines if Product structure is exported.
The option [1] is valid for Pro (or higher) license level. It works as [0] otherwise.
| Type: |
Short |
| Saved in: |
Registry |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: No product structure: Exports a flat structure without components in the target document, whether the BricsCAD® document has a product structure or not. 1: Export product structure: Exports the BricsCAD® product structure data (if existing) to the target document. |
