FBXEXPORTTEXTURESPATH system variable
Fbx Export Textures path
The file path for FBX Export Textures.
This setting is only used when the FBXEXPORTTEXTURES system variable is set to 2.
BricsCAD only
| Type: |
String Standard |
| Saved in: |
Preference |
BricsCAD only
| Type: |
String Standard |
| Saved in: |
Preference |
