FBXVERSION system variable
FBX version
Controls the FBX export version.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
1 to 2 |
| Default value: |
1 |
| Possible options: |
1: FBX binary file. 2: FBX ASCII file. |
Note: The FBXVERSION system variable sets the FBX file format when the EXPORT command runs from a script or when file dialog boxes are disabled (FILEDIA = 0).
