FIELDEVAL system variable
Field update mode
Specifies the way fields are updated. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 31 |
Default value: | 31 |
Possible options: |
0: Not updated 1: Updated on open 2: Updated on save 4: Updated on plot 8: Updated on use of ETRANSMIT 16: Updated on regeneration |
