FILEDIA system variable
File dialog
Toggles the display of file dialog boxes. If off, enter a tilde (~) to bring up the file dialog. This also works for LISP functions and command fields in tool definitions.
| Type: | Boolean |
| Saved in: |
Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t display dialog boxes On (1): Display dialog boxes |
