FILLETRAD system variable
Fillet radius
The last radius used with the FILLET command.
Type:
Real
Saved in:
Drawing
Default value:
0.5
Note: The default value applies when the MEASUREMENT system variable is set to 0 and the INSUNITS system variable is set to inches. When the MEASUREMENT system variable is set to 1 and the INSUNITS system variable is set to millimeters, the default value is 10.0.
