FILLETWELDINGMAXGAPRATIO system variable
Maximal ratio of a gap to a weld size
Sets the default maximal ratio of a gap between a welding part and the fillet weld size, see the FILLETWELDINGZSIZE system variable.
Values between 0.0 and 0.8 are accepted.
BricsCAD only
| Type: |
Real |
| Saved in: |
Drawing |
| Range: | 0 to 0.8 |
| Default value: | 0.4 |
