FILLETWELDINGMAXGAPRATIO system variable
Maximal ratio of a gap to a weld size
Sets the default maximal ratio of a gap between a welding part and the fillet weld size, see the FILLETWELDINGZSIZE system variable.
Values between 0.0 and 0.8 are accepted.
BricsCAD only
Type:
Real
Saved in:
Drawing
Range: 0 to 0.8
Default value: 0.4
Related variables
  • FILLETWELDINGCOMBINEADJACENT system variable
  • FILLETWELDINGZSIZE system variable
Related commands
  • BMWELDING command
