FILLMODE system variable
Fill mode
Shows fills for multilines, traces, solids, hatches (includes solid-fill), and wide polylines.
A REGEN is required.
If off, all filled entities display and print as outlines, this will also reduce the time it takes to display or print a drawing.
| Type: |
Boolean |
| Saved in: |
Drawing |
| Range: |
On |
| Possible values: |
Off (0): Entities are not filled On (1): Entities are filled |
