FILLMODE system variable
Fill mode
Specifies whether multilines, traces, solids, hatches (including solid-fill), and wide polylines are filled in. If FILLMODE is off, all filled entities display and print as outlines, this will also reduce the time it takes to display or print a drawing.
| Type: | Boolean |
| Saved in: | Drawing |
| Range: | On |
| Possible values: |
Off (0): Entities are not filled On (1): Entities are filled |
