FONTALT system variable
Alternate font
The substitute font used when a text font cannot be found.
Type:
String
Saved in:
Registry
Default value:
simplex.shx
Note:
  • This system variable specifies the substitute font used when a text font cannot be found.
  • If a font is missing and no replacements are defined in the default.fmp or fontalt.fmp files, BricsCAD® uses the simplex.shx, which is set by default by the FONTALT system variable.
  • When FONTALT cannot replace the missing font, the operating system tries to substitute it. If the operating system also cannot find a replacement, the text appears as ???.
  • It is recommended to always use the original font to maintain a consistent visual appearance across different platforms. In addition, it is recommended to choose fonts that support the language in which the text is written.
