FONTMAP system variable
Font mapping file
The font mapping file.
| Type: | String |
| Saved in: | Registry |
| Default value: |
default.fmp |
Note:
- This system variable specifies the font mapping file.
- A font mapping file has one font mapping per line.
- The semicolon (;) separates the original font used in the drawing from the font that replaces it.
- If a font style is written without an extension, the mapping is done for styles containing the font map with SHX and TTF extensions.
Example:
- If you have a line, such as
font;simplex.shx, the mapping is done for styles containing font.shx and font.ttf, using simplex.shx. - If the mapping includes an extension, such as
font.shx;simplex.shx, the mapping to simplex.shx will work for styles including font.shx but not for font.ttf.
