GEARTEETHNUMBER system variable
Maximum number of sproket teeth
Controls the number of teeth for sprockets, during the -BMHARDWARE command. Use this option to insert sprockets with simplified or full geometry.
Values between 0 and 1000 are accepted.
Note: This number must be greater or equal to the number of teeth of the inserted sproket to create a sproket with full geometry. 1000 is enough to insert any sproket from the library with a full set of teeth.
BricsCAD only
| Type: |
Short |
| Saved in: |
Registry |
| Default value: | 1 |
