GENERATEASSOCATTRS system variable
Generate associative attributes
Enables the generation of associative attributes on 3D entities.
BricsCAD only
| Type: | Boolean |
| Saved in: | Workspace |
| Default value: | Off Note: The default value is On for Mechanical and BIM workspaces. |
| Possible values: | Off (0): Do not generate associative attributes for 3D entities On (1): Generate associative attributes for 3D entities |
