GENERATEASSOCATTRS system variable
Generate associative attributes
Enables the generation of associative attributes on 3D entities.
BricsCAD only
| Type: |
Boolean |
| Saved in: |
Workspace |
| Default value: |
Off Note: The default value is On for Mechanical and BIM workspaces.
| Possible values: |
Off (0): Do not generate associative attributes for 3D entities On (1): Generate associative attributes for 3D entities |
