GENERATEASSOCVIEWS system variable
Generate associative drawings
Enables associative dimensions for drawings generated with the BIMSECTIONUPDATE, VIEWBASE and VIEWSECTION commands.
As a result, dimensions are updated in the associated Paper Space viewports and BIM section drawings.
BricsCAD only
Type: |
Boolean |
Saved in: |
Workspace |
Default value: |
On Note: The default value is Off for Drafting workspace.
Possible values: |
Off (0): Deactivate associative dimensions On (1): Activate associative dimensions |
