GENERATEASSOCVIEWS system variable
Generate associative drawings
Enables associative dimensions for drawings generated with the BIMSECTIONUPDATE, VIEWBASE and VIEWSECTION commands.
As a result, dimensions are updated in the associated Paper Space viewports and BIM section drawings.
BricsCAD only
Type:
Boolean
Saved in:
Workspace
Default value:
On
Note: The default value is Off for 2D Drafting, 2D Drafting (Modern) and Toolbars (Classic) workspaces.
Possible values:
Off (0): Deactivate associative dimensions
On (1): Activate associative dimensions
