GEOMAPMODE system variable
Online map style
Reports the online maps style for the active viewport.
| Type: |
Short |
| Saved in: |
Drawing |
| Default value: |
0 |
| Possible options: |
0: Online maps are not displayed. 1: The online maps style is set to Aerial. 2: The online maps style is set to Road. 3: The online maps style is set to Hybrid. 4: The online maps style is set to Esri Imagery. 5: The online maps style is set to Esri Open Street Map. 6: The online maps style is set to Esri Streets. 7: The online maps style is set to Esri Light Gray. 8: The online maps style is set to Esri Dark Gray. |
