GLSWAPMODE system variable
GL Swap Mode
Controls the swap method used when drawing with the GL engine. Depending on the hardware driver used, the visual effect may differ between these options.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: |
0 to 4 |
| Default value: | 2 |
| Possible values: |
0: Call glCopyPixels to copy back to front, don't call glXSwapBuffers. 1: Call glCopyPixels to copy back to front, then call glXSwapBuffers. 2: Call glXSwapBuffers, don't call glCopyPixels. 3: Call glXSwapBuffers, then call glCopyPixels to copy front to back. 4: Do nothing - for testing purposes only. |
