GSDEVICETYPE3D system variable
3D graphic system device
Set current graphic system device for rendered output for Hidden, Gouraud (with edges) and Flat (with edges) visual styles.
Other rendered visual styles, such as Modeling and Realistic, will always use RedOpenGL.
BricsCAD only
| Type: |
Short |
| Saved in: |
Preference |
| Range: |
0 to 1 |
| Default value: |
1 |
| Possible values: |
0: OpenGL 1: RedOpenGL |
